翻譯Gutenbergブロック
翻譯Gutenbergブロック
1,900 表示
(@jason6666h)
投稿: 15
こんにちは、私はちょうどあなたのテーマを購入し、英語と中国語にGutenbergブロックを翻訳する方法を知っていただきたいと思います、ありがとうございました。 (Loco translateで翻訳に失敗しました。)
Oracle
Loco translate
投稿済 : 15/06/2022 1:49 am
You could use translation plugins like WPML, TranslatePress for contents. SWELL theme itself may not be fully translatable, but perhaps you could translate some strings with Loco Translate.
投稿済 : 15/06/2022 10:19 am
しらこ and suya reacted
(@jason6666h)
投稿: 15
I just tried to use .po file to convert to json file through wp-cli, but the part of gutenberg block was not translated successfully, could you give me more tips?
I used the wp-cli command: wp i18n make-json po-filename.po --allow-root
投稿済 : 15/06/2022 6:53 pm
投稿者:: @jason6666h
Could you attach a screenshot mentioning which block and which part you are exactly referring to?
投稿済 : 15/06/2022 7:02 pm
(@jason6666h)
投稿: 15
@skillsharejp This is the part I want to translate.
Snipaste 2022 06 15 13 11 21
And I also found that when I use the command, 103 JSON files are generated, but I see that there is only one JSON file in the English translation. I don't know why this is happening.
この投稿は4年前ずつjason6666hに変更されました
投稿済 : 15/06/2022 7:07 pm
Sorry, I have never used Loco Translate and I am not sure about the cause either.
I am not loading the translation files for the scripts for each block, only for 'swell_blocks' (/build/blocks/index.js).
This means that `wp_set_script_translations()` only needs to be done once.
投稿済 : 15/06/2022 8:59 pm
Did you also check this stackoverflow answer?
https://stackoverflow.com/a/66381707
投稿済 : 16/06/2022 10:46 am
(@tetsuaki-hamano)
投稿: 25
Hi @jason6666h,
Translation of Gutenberg blocks (JavaScript translation) is a mechanism introduced in WordPress 5.0. Therefore, translation will often be difficult with translation plugins. I also tried to translate using Loco Translate, but it did not work.
If you can run the npm command on your computer, the following method would be easiest. This is an example of generating a translation file in traditional Chinese.
  • Open the directory where you installed WordPress and go to `wp-content/themes/swell/languages`.
  • Copy `en_US.po` and create `zh_CN.po`.
  • Use this file for translation; you may want to use a tool such as Poedit.
  • Open a terminal and move to the `languages` directory.
    `cd /path/to/wp-content/themes/swell/languages`
  • Generate a JSON translation file for Gutenberg. Use npx and execute the following command:
    `npx po2json@1.0.0-beta-3 zh_CN.po swell-zh_CN-swell_blocks.json -f jed `
  • `swell-zh_CN-swell_blocks.json` file will be generated in the languages directory.
  • Change the site language to Traditional Chinese and confirm that the translation has been applied to the SWELL blocks.
投稿済 : 26/01/2023 7:37 pm
jason6666h reacted
(@chi2-1)
投稿者:: @jason6666h
Hi~ Did you successfully translate Japanese into Chinese later? Because I am currently encountering the same problem, and my Google adsense keeps showing that Adx.txt cannot be found.
Website: in7daily.com
email:in7daily@gmail.com
投稿済 : 26/12/2024 3:20 am
